Battery goes dead overnight, I did a draw test, test light stays lit with all fuses removed. What next
Oct 27, 2009 at 10:17 AM
✓Experienced Mechanic
Hi there check with an Amp meter to get the exact draw, also make sure that you check with any fusible links off and also the alternator as a faulty diode will feed back voltage and still give a reasonable charge rate, check this next.
