1998 Dodge Intrepid Auto Shutdown Relay
162,742 MILES • 6 CYL • FWD • AUTOMATIC
JDAWG5732
Relay clicks when ignition switch engaged...engine won't turn over. Relay continues clicking when key is removed.Fuel pump pulses while ASD relay is clicking.Also, Idle Air Control valve might be bad,because the few times it has cranked,it will not idle. We did replace Fuel Pump and Intake gasket and Battery Cable ends and charged battery
Mar 4, 2010 at 5:02 AM
  • 110,251 POSTS
If the starter isn't working, have you checked the starter relay? As far as it running poorly, have you checked for fuel pressure?
Mar 18, 2010 at 4:13 AM
