1998 Dodge Intrepid A/C COMPRESSOR DRIVE BELT CHANGE
98,000 MILES • 6 CYL • FWD • AUTOMATIC
LARRY SIMRIN
I would like to replace the compressor belt. The serpentine belt has already been removed, but I cannot see how to tighten/loosen the compressor belt tension. Coult it be that the a/c clutch pulley must be removed??? The harmonic balancer on the engine (3.2) has a "dual" pulley. The serpentine belt is driven by the front section and the compressor belt is all by itself, using the rear pulley. I cannot see any adjustment to loosen the a/c belt.!!!???
Thanks for any help you can give me.
Feb 11, 2008 at 4:03 AM
BMRFIXIT
  • 19,053 POSTS
[quote:ee690d103d="larry simrin"]Air Conditioning problem
1998 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 98000 miles
Thanks for any help you can give me.[/quote:ee690d103d]
same as the other belt is a
has an adjuster bolt on the tensioner pulley
loosen the cnter nut then release the bolt on the side of it
Feb 12, 2008 at 10:24 AM
