1997 Dodge Intrepid valve body
JOEMAC52
Transmission problem
1997 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 157k miles
how do you get the valve body out to change the transmisson control seleanoid
Aug 9, 2009 at 1:54 PM
BMRFIXIT
  • 19,053 POSTS
Raise and support vehicle.
Disconnect TR sensor harness connector.
Disconnect shift cable from shift lever on transaxle. Rotate shift lever on transaxle fully clockwise. Remove shift lever from manual valve lever on transaxle.
Remove bolts and oil pan.
CAUTION:Overdrive and underdrive accumulator pistons and springs may fall from transaxle case when removing valve body.
Note location of components for reassembly reference. Components must be installed in original location.
Remove bolts, oil filter retainers, oil filter and "O" ring.
Remove bolts and valve body with transfer plate from transaxle
Aug 10, 2009 at 10:48 PM
