1997 Dodge Intrepid testing water pump?
172,000 MILES • 6 CYL • FWD • AUTOMATIC
ANAYAWOLF
First let me say that my water pump is leaking but I need to know if there is a way to see if it is just the seal or the pump itself? I can do the work and I know how but I need to know how to find out if it is a bad pump or just a seal that needs replacing.
May 11, 2009 at 5:03 AM
RACEFAN966
  • 5,029 POSTS
Welll you will need to presurize the system with a pressure tester and see where the leak is actually coming from to determine if it is just the seal or not.
May 11, 2009 at 12:24 PM
