1997 Dodge Intrepid overheating issue
FLUKEY
Engine Cooling problem
1997 Dodge Intrepid 6 cyl Two Wheel Drive 166,00 miles
gentlemen i need your help please. my sisters 97 intrepid overheats. fan will not come on, i found the fuse was blown. i jumpered the fuse and still nothing. when i un-plugged the ect sensor fan came on. replaced the ect sensor and still the same, no fan. any help please????
Oct 9, 2009 at 7:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
have you tested the cooling fan relay(s) ? will the fan come on with the A/C switched to High ?
Oct 9, 2009 at 7:59 AM
FLUKEY
i checked the fuse box again and was not getting power. swapped the relays, jumped the fuse and the fan came on. however i noticed that after about a minute, the jumper wire got VERY hot so i pulled it. the ac does not work, so that shouldn't be an issue. thanks.
Oct 9, 2009 at 8:20 AM
FLUKEY
i think i have a short somewhere, when i pull the relay and reset it, fan comes on, however j-wire gets very hot. can someone at least post a wiring diagram????? please???
Oct 9, 2009 at 9:19 AM
BLUELIGHTNIN6
  • 16,542 POSTS
see if this helps..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1059.jpg
Oct 10, 2009 at 11:26 AM
