hello, this car has a 3.5 doc. i changed the fuel pump and filter and pump relay. also changed crank and cam sensors and asd relay. fuel pump pressure while cranking is 40psi. compression on all but one cylinder is good. the one bad cylinder on drivers side front has about half of the others,( about 65psi). i ohmed the coil pack and its ok with plenty of spark while cranking. pulled the plugs and they come out wet, so injectors must be working. also used starting fluid just in case. the timing belt was done about 6 mo. ago but checked to see if both cams are turning. they are. still no start! HELP! i'm about to blow it up for revenge!
Jan 9, 2008 at 2:47 PM
