1997 Dodge Intrepid Misfire problem?
200,000 MILES • 6 CYL • FWD • AUTOMATIC
DAVID08
Ok, my car seems to "bog" down when i'm driving normally. Loses power, and even if i push the pedal to the floor, it doesn't help, and doesn't accl. I know that i have 2 cylinders misfiring, and 2 of my O2 sensors are bad. I also think i have a bad ground b/c my lights dim in and out when i'm sitting at a stop light, and i had the alternator checked, it was ok. So could any of these things be the problem? Or could it be something else?
sorry, its a 1997 not 2007
Jan 17, 2008 at 8:58 AM
BMRFIXIT
  • 19,053 POSTS
[quote:008a9d601b="david08"]Engine problem
2007 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 200000 miles
Ok, my car seems to "bog" down when i'm driving normally. Loses power, and even if i push the pedal to the floor, it doesn't help, and doesn't accl. I know that i have 2 cylinders misfiring, and 2 of my O2 sensors are bad. I also think i have a bad ground b/c my lights dim in and out when i'm sitting at a stop light, and i had the alternator checked, it was ok. So could any of these things be the problem? Or could it be something else?[/quote:008a9d601b]
2007 and 200000 miles
I like to know where did you do all them miles went to the moon and back???
if engine misfiring alternator out put will be effected
also the o2 sensors
correct the misfire issue first
Jan 17, 2008 at 9:08 AM
HUNTER02
  • 5 POSTS
[quote:629d420be1="david08"]Engine problem
Ok, my car seems to "bog" down when i'm driving normally. Loses power, and even if i push the pedal to the floor, it doesn't help, and doesn't accl. I know that i have 2 cylinders misfiring, and 2 of my O2 sensors are bad. I also think i have a bad ground b/c my lights dim in and out when i'm sitting at a stop light, and i had the alternator checked, it was ok. So could any of these things be the problem? Or could it be something else? could be several things what size of engine ?. the miss fire can be caused by bad plugs and wires ,fuel filter will lso do this
sorry, its a 1997 not 2007[/quote:629d420be1]
Jan 12, 2009 at 2:11 PM
BMRFIXIT
  • 19,053 POSTS
If you know that you have two cylinders misfiring and 2 bad o2 sensors ,
need to start by fixing what you know is wrong at 1st
check spark plugs ,wires and coil
replace if needed
check injectors
do a compression test
Jan 12, 2009 at 10:00 PM
HUNTER02
  • 5 POSTS
well i would first take alook at the plugs and wires also a bad fuel filter will cause this also
Jan 13, 2009 at 6:21 AM
