1997 Dodge Intrepid LEAKING WATER PUMP
201,000 MILES • 6 CYL • FWD • AUTOMATIC
QUENTINMH
I HAVE REPLACED THE WATER PUMP BUT ONE OF THE BOLTS BROKE OFF IN THE PUMP HOUSING
Apr 15, 2010 at 4:26 PM
CH112063
  • 1,320 POSTS
Hi, try and use a hammer and tiny sharp punch to tap it out counter clockwise. You would be suprised how little tension there may be. Drilling and using a remover tool is the only other way. ok use finess. It works, when its out far enough you can cut a slot and use a screwdriver but I doubt if it will be difficult. Thanks, bye
Apr 18, 2010 at 1:49 PM
