1997 Dodge Intrepid just a mess!
135,000 MILES • 6 CYL • FWD • AUTOMATIC
R6RAINZ9
  • 6 POSTS
3.5 Liter
original message: I am a single mom on a very tight budget, and was given a 1997 Dodge Intrepid. The guy who gave it to me said he drove it to work one day and when he got off work, it wouldn't start and that it had previously overheated. He "says" someone "told" him that the water pump 'froze up' and that it would cost him $800.00 to fix it...
I personally don't have that kind of money, but thought maybe, it wasn't something SO costly. My son 'tinkers' with cars, so he is going to attempt to fix it for me so I can have a car again... I REALLY need this car, and it's the day before Christmas. This would be a wonderful Christmas present for me in these difficult times.... Can anyone give me suggestions to get this car running at an inexpensive cost... Such as, the first steps to take to find out why it won't start and why someone told him it's a 'frozen' water pump and will cost $800.00... Thanks a million!
******************************************[img:e176115f59]http://www.2carpros.com/forum/automotive_pictures/134169_Cristy20_2.jpg[/img:e176115f59]
First off, the previous owner said it was a "frozen" waterpump.
Hooked jumper cables for about 10 minutes, tried to crank it, it only pulled power from the truck. Didn't start.
Put a new battery in it and it didn't start. Made a click noise and could smell fuel. Lost charge on the battery. If we can't get it started, how can we find out what is wrong? What do I do to get it started? Could it be the starter or alternator and not the waterpump?
Oh, someone, anyone, please help!
Dec 29, 2007 at 4:51 AM
BMRFIXIT
  • 19,053 POSTS
[quote="r6rainz9"]Engine problem
1997 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 135000 miles
Oh, someone, anyone, please help![/quote
what is the engine size on it
do you have a timing belt or not
try removing all the drive belts(not the timing belt) and then try to crank it.
check oil
let me know
Dec 29, 2007 at 5:25 AM
BMRFIXIT
  • 19,053 POSTS
From: r6rainz9 To: BMRFIXIT Posted: Sat Dec 29, 2007 8:31 am Subject: Re: help please the engine is a 3.5 (i think), it is an Intrepid ES... And it does have a serpantine belt and a timing belt... so if i take the serpantine belt off, it could start? if you was told its a water pump then the water pump drivin by the timing belt
https://images.2carpros.com/forum/automotive_pictures/99387_35_1.jpg
Dec 29, 2007 at 6:00 AM
R6RAINZ9
  • 6 POSTS
Took the Serpantine belt off and the water pump moves freely by hand...it still just clicks...oil is very thick and black. (But it has been sitting for a few months). Starter? or what now?
Dec 29, 2007 at 6:14 AM
R6RAINZ9
  • 6 POSTS
son wants to know if it could be the solenoid?
Dec 29, 2007 at 6:53 AM
ROWTIEAR
  • 91 POSTS
Tell your son to try and turn the engine over by hand using a socket and a power bar on the crankshaft pulley.
If the engine turns freely this will eliminate the possibility of the engine or waterpump being siezed.
If it does turn freely the problem is likely related to the starter.
Dec 29, 2007 at 7:03 AM
OLDTECH2
  • 64 POSTS
I'm with rowtiear about turning the engine with a bar and socket. If the engine turns, then the problem is likely to be starter, solenoid, or battery cable related. You can eliminate the belt driven accessories by removing the external belts. I've seen accesssories prevent an engine from turning over when they lock up.
The water pump is timing belt driven, and is not visible without removing the covers on the front of the engine. Is your son sure that he's looking at the water pump?
The diagram that BMRFIXIT included shows the front of the engine with the alt/ps and ac belts removed along with the harmonic balancer and front engine covers.
There should be 2 belts that are visible with the harmonic balancer. 1 drives the alternator and power steering pump with an idler as tensioner. The other drives the ac compressor with an idler as tensioner. Removing these belts is not going to show the water pump.
At this point, there's no reason to be concerned about black oil in the crankcase. Just make sure that the level is up. Once you get the engine running, then you can change the oil.
Dec 29, 2007 at 8:59 AM
BMRFIXIT
  • 19,053 POSTS
check relay box it has a relay for the starter
i think water pump run by the timing belt check pic up
also do what suggested above
you may need to step back relax and start fresh form the basic up
Dec 29, 2007 at 11:41 AM
R6RAINZ9
  • 6 POSTS
replaced the starter... started once...fuel injectors are loose and gas is leaking...
so what is the next step?
Jan 4, 2008 at 7:32 AM
OLDTECH2
  • 64 POSTS
Is the fuel leak external where you see it spraying?
If so, the rail isn't bolted down right, or you've got injector o-rings blown. I'd bet that the car has been sitting, and the o-rings are blown. The injectors are pushed up into the rails, then the assy is popped into the intake and bolted down.
To get a good look, take the plenum off the top of the engine. It's the big aluminum "spider" on top of the engine. I've found that just about everything I do, I wind up with that off to get it out of the way. Make sure that you stick rags etc down the intake holes so you don't get a bolt or something down in the engine. Turn the key to "on" the fuel system should pressurize and the leak will be really visible. Keep in mind that the fuel system is pressurized and fuel will spray at any leak.
Congratulations on getting it to fire! You're getting close!
Jan 4, 2008 at 7:46 AM
DAVE'S BIG BACKYARD!
  • EXPERT
  • 262 POSTS
it needs injector o rings and make sure the fuel rail is tight.
Apr 5, 2011 at 4:44 PM
