1997 Dodge Intrepid freeze plug
178,000 MILES • 6 CYL • FWD • AUTOMATIC
HUBERTWILLIAMS
doing the texas freeze my freeze plug cracked and theres no water in the engine so how much does that problem cost me
Mar 12, 2010 at 9:53 AM
  • 110,248 POSTS
I didn't think it got that cold there. As far as the freeze plug, the part is cheap, under 3.00. However, the I can't tell you the labor cost. It is based on location of the plug. If it is an easy one to access, it shouldn't take more than .75 hour. If a difficult, it could take several hours to access. Don't forget you will need coolant. Make sure to have a 50% water and 50% coolant mixture. That way it won't freeze until -45°F
Mar 18, 2010 at 3:24 AM
