I have had this car for a year now and only experienced a few times it overheated. The overheating seemed to be caused by air bubbles in the antifreeze system until is stopped circulating. To solve the problem I would bleed the valve right above the thermostat until the air was gone. Until recently this seemed to work. Now when the sealed system is released by either opening the bleed valve or opening the radiator cap all of the antifreeze drains out the bottom of the engine somewhere within 15 minutes. With the system sealed I can get around for a day or two just a couple miles. I have seen people in other forums with similar problems. They suggest replacing a head gasket due to a bad dodge design. Is this the solution? How much will it cost? Is it difficult to repair myself?
Sep 20, 2008 at 7:11 AM
