Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Climate Control
Air Conditioner
Compressor
1997 Dodge Intrepid Compression rating
1997 DODGE INTREPID
110,000 MILES • 6 CYL • FWD • AUTOMATIC
AEMMERT
MEMBER
What is the rate or number it shoud be when a compression check is done
Jun 21, 2009 at 11:06 AM
BUDDYCRAIGG
Experienced Mechanic
there isn't a sold number for a compression test.
they could be anywhere from about 110 to 160.
the important part is that they are all within 10% of each other.
say you have
120
125
130
132
127
120
that would be fine,
if you have
120
125
130
100......
127
120
then you have a problem
here's some more info
https://www.2carpros.com/dia/how_to_check_compression.htm
Jun 21, 2009 at 11:22 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
