1997 Dodge Intrepid Colant Leak Near Drain Plug
1997 DODGE INTREPID
13,000 MILES • 6 CYL • FWD • AUTOMATIC
GYMRAT990
After draining the coolant out and replacing the thermostat, I closed the drain valve and poured coolant into the fill tank a few minutes later without starting the engine coolant began dripping from the bottom side of the radiator from what appears to be a hole in the underside of the radiator slightly to the left the drain plug. I've never had a leak before this what could this be? The picture is from me laying under the car looking up.[img:f75c2c7d7c]http://www.2carpros.com/forum/automotive_pictures/324967_radiator_1.jpg[/img:f75c2c7d7c]
Feb 28, 2009 at 2:55 PM
  • 31,937 POSTS
HI there,
he pic is a bit blurry, but i feel you may have a split in the radiator, i would get it cleaned & flow tested and pressure tested just to make sure., start here.
mark (mhpautos)
Feb 28, 2009 at 4:27 PM
