the car is missing real bad.How can i tell if it is the coil pack and how hard is it to ghange one? I have already changed the plugs.
Nov 13, 2008 at 2:53 AM
ZACKMAN
✓Experienced Mechanic
Your check engine light should tell us if it is the coil. As you have replaced the plugs, and still missing, I would go get the computer scanned. You probably just need new plug wire set ($25) , instead of the coil ($65)
Nov 14, 2008 at 3:00 PM
HUNTER02
MEMBER
[quote:ac32951686="Bangerman7"]1997 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 140000 miles
the car is missing real bad.How can i tell if it is the coil pack and how hard is it to ghange one? I have already changed the plugs.[/quote:ac32951686]did you change the wires also
