1997 Dodge Intrepid Check engine light codes
176,000 MILES • 6 CYL • FWD • MANUAL
CRADEE
I own a 1997 intrepid that recently had the transmission repaired. Shortly after the repair, the check engine light came on. I disconnected the battery to reset the computer but the light came back on again a few days later. I did the "on/off" sequence to determine the error codes and the flashes/pauses indicated the codes are "12" and "21" in that order. The car seems to run ok so I don't think it can be anything too major. Can you tell me what these codes mean so I can get the needed repairs...
Thanks!
May 8, 2008 at 1:25 AM
BMRFIXIT
  • 19,053 POSTS
Code 21
Its related to an oxygen sensor not active
you should scan it for more detailed code ( P_ _ _ _ )
May 8, 2008 at 3:37 PM
