1997 Dodge Intrepid Bypass hose fitting broken off of engin
182,000 MILES • 6 CYL • 2WD • AUTOMATIC
SHORBAL
I have the 3.3 L engine. The copper fitting coming out of the housing for the water pump broke off. How do I remove the portion of the fitting left in the engine? I was trying to replace the bypass hose which had burst.
Nov 12, 2008 at 2:40 AM
  • 110,244 POSTS
Hi:
I'm not quite sure which part you are talking about. However, all brass fittings are pressed fit. Where is the broken one you are refering to?
Nov 12, 2008 at 11:30 AM
