Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Intrepid
Exterior Light
Turn Signal
Not Working
1996 Dodge Intrepid turn signal
1996 DODGE INTREPID
114,000 MILES • 6 CYL • 2WD • AUTOMATIC
MKLER
MEMBER
i have a 1996 dodge intrepid, the turn signals do not work i checked the fuse and it was good, what else should i check
Mar 21, 2008 at 9:54 AM
BMRFIXIT
Experienced Mechanic
Check /replace combination flasher right of steering column
and if all OK check replace the multifunction switch
Mar 21, 2008 at 12:48 PM
See below when it leaves the switch from 1 and 3 it goes to the lights. HTH
Mar 21, 2008 at 11:23 PM
Try removing the upper steering column cover you'll be looking for a black box little bit to the left of the pass. side towards the steering column.
Mar 22, 2008 at 9:56 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
