i have 1996 dodge intrepid 3.5L with 141,000 on it i just got it and it was over heating i replaced the thermostat and the engine coolant sensor. it over heats while it sits and on the drive 15 to 20 min on the sit and 10 to 13 min on the drive before the needle going all the way to the red.the upper radiator hose is or becomes hot so i figure it was not the radiator or the thermostat but as it runs the coolant goes back to the resivor fill box and comes out the over flow tube (hot) i was woundering what else can i check do you think its the water pump that could be making it over heat or that radiator bad i don't know just seeing if i could get some help.
Dec 23, 2007 at 11:36 AM
