1996 Dodge Intrepid tourqe convertor lock up
146,000 MILES • 6 CYL • FWD • AUTOMATIC
RAMZGA
  • 12 POSTS
My tourqe convertor seems to is haveing a problem lockeing up i think, Around 43 mph it feels like the engin is skipping,I can lighty touch the breaks and it smooths out. Is it possible to uhook the wire controlling the lock up? and if so witch wire is it?
Nov 25, 2009 at 5:50 AM
MERLIN2021
  • 17,250 POSTS
First read the codes, check your email, for 96' model years there is a flash update the dealer can perform to correct this problem, read the PDF files in your email...one require part replacement, the other a flash update.
Using Malfunction Indicator Light (MIL) 1. Ensure battery is fully charged. Turn ignition on and note operation of MIL. The MIL is located on instrument panel. When ignition is first turned on, MIL should come on to verify bulb and circuit operation, and then go off. 2. Turn ignition on, off, on, off and on within 5 seconds. Record 2-digit Diagnostic Trouble Codes (DTCs) as displayed by flashing MIL. 3. For example, DTC 24 will be displayed by 2 flashes, short pause, and then 4 flashes. A short pause will exist between first and second digits on DTC. If more than one DTC is stored, after first DTC is displayed, there will be a longer pause and then another stored DTC will be displayed. 4. Once all DTCs are recorded, proceed to retrieving DTCs using scan tool to ensure all DTCs are obtained. See USING SCAN TOOL. NOTE: If MIL does not come on and then go off, bulb circuit may be defective, or problem area may exist on CCD Bus between Powertrain Control Module (PCM) and instrument cluster. If problem exists with CCD Bus, this problem may be displayed when using scan tool to retrieve DTCs.
Nov 25, 2009 at 9:58 PM
