1996 Dodge Intrepid STARTS AND QUITS COLD.
ANGELO1520
Engine Performance problem
1996 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
WHEN ENGINE SITS OVERNIGHT,CAR STARTS AND QUITS A DOZEN TIMES BEFORE IT STAYS RUNNING.
CHECKED FUEL PRESSURE,45 LBS AND DOES NOT DROP WHEN CAR STALLS. CHECKED CRANK AND CAM
SIGNALS,DOES NOT DROP OUT. REPLACED CRANK SENSOR JUST BECAUSE. NO CODES STORED,ECT AND MAP SENSOR READING CORRECTLY. I CAN COMMAND RPM UP AND DOWN WITH SNAP ON SCANNER,SO I KNOW IAC IS WORKING. DONT KNOW WHERE TO GO FRM HERE. ANY HELP IS APPRECIATED. THANKS.
Jun 7, 2010 at 4:11 AM
  • 75,988 POSTS
Hi angelo1520, Welcome to 2carpros and TY for the donation
Lets try cleaning out the IAC and EGR valve passages/pintle, Test the TPS and last the ASD relay-
Jun 23, 2010 at 8:17 AM
