1996 Dodge Intrepid replace cooling fan motor
KRYPTONONLY2
Engine Cooling problem
1996 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
im trying to figure out how to remove the cooling fan motors on a 1996 dodge intrepid im trying to remove the fans from the fan shrouds can someone please help me
Sep 3, 2009 at 1:25 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Disconnect negative battery cable. Unplug the fan electrical harness connector from the EFI module. Remove the retaining screws and clips that secure the cooling fan assembly to the radiator.
https://images.2carpros.com/forum/automotive_pictures/261618_0900c1528006a8d8_1.jpg
Remove the cooling fan assembly from the radiator. If it is necessary to separate the fans from the motor shafts, remove the retaining clip or nut from the motor shaft and gently, but firmly, force the fan off of the shaft. If necessary, separate the fan motors from the cooling fan shroud assembly by removing the mounting screws.
https://images.2carpros.com/forum/automotive_pictures/261618_2_22.jpg
Sep 3, 2009 at 1:34 PM
