1996 Dodge Intrepid 6 cyl Front Wheel Drive
the water pump was leaking and when we went to replace the water pump the bottom bolt was broken off, we tried to drill out the bolt with no success, I need to know what the name of the cover ( or the back side of the cover) that the water pump bolts to is. The motor is a 3.5 L overhead cam V6, also any other info you think I may need.
Tuesday, April 13th, 2010 AT 3:10 PM
