Hi:
If it only overheats sitting, chances are the radiator fans are not working. When you are driving, cool outside air passes through the radiator. When you stop, so does the air. After the engine hits a certain temp, the fans should come on and draw air through the radiator to cool the engine. Let me know if you checked that. Also, let me know if this problem has ever happened while at highway speed.
SPONSORED LINKS
Friday, July 16th, 2010 AT 11:15 PM
