1996 Dodge Intrepid overheat
AWIREN
Engine Cooling problem
1996 Dodge Intrepid Two Wheel Drive Automatic 87000 miles
Engine overheats when standing in traffic. Neither the radiator or A/C fan is operating though the compressor is engaging. Common point appears to be RFI module between fans.
appears to be plugged in properly. Any suggestions?
May 10, 2008 at 8:05 AM
  • 75,988 POSTS
Have you replaced the thermostat if not do so, also check the coolant level. Check the coolant temperature gauge switch and engine coolant temperature sensor-the computer takes their input signals to activate the fan thru the relays/RF module See below cooling fan circuitry
https://images.2carpros.com/forum/automotive_pictures/12900_cf1_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cf2_4.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_cf3_1.jpg
May 11, 2008 at 11:06 AM
