1996 Dodge Intrepid low rpm
94,000 MILES • 6 CYL • FWD • AUTOMATIC
SIWYTOM17
  • 8 POSTS
While driving the engine shuts down by itslef. I then start the car and it starts fine. The problem reoccurs a couple dys later. The RPM is too low, when the car is in drive but stopped the RPM is 500. When I put it in neutral, the RPM goes to 700.
Jun 18, 2010 at 12:12 PM
SIWYTOM17
  • 8 POSTS
[quote:488874d6b5="siwytom17"]Engine Performance problem
1996 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 94000 miles
While driving the engine shuts down by itslef. I then start the car and it starts fine. The problem reoccurs a couple dys later. The RPM is too low, when the car is in drive but stopped the RPM is 500. When I put it in neutral, the RPM goes to 700.[/quote:488874d6b5]
Jun 18, 2010 at 12:14 PM
CARADIODOC
  • 34,413 POSTS
Hi siwytom17. Was the battery recently disconnected or run dead? If so, "minimum throttle" must be relearned before the Engine Computer will know when it must be in control of idle speed. There are things you can do too to determine if the Automatic Idle Speed motor is working.
caradiodoc
Jun 18, 2010 at 12:26 PM
SIWYTOM17
  • 8 POSTS
What are these things that must be determined?
Jun 18, 2010 at 12:53 PM
CARADIODOC
  • 34,413 POSTS
First of all, when you start the engine, the idle speed is supposed to go up to around 1500 rpm for a couple of seconds, then come back down to around 800 rpm. That "idle flareup" proves the Automatic Idle Speed motor is working and the computer has control of it. On some engines that idle flareup won't occur if minimum throttle is lost from memory.
The second test involves disconnecting a fuel injector while the engine is idling. Engine speed will drop at first, and the computer will respond by bumping it back up. The same thing will happen if a second and third injector is unplugged. You can do the same thing by shorting out a spark plug wire, but don't do that for long because the unburned fuel will overheat the catalytic converter very quickly.
If you think minimum throttle has been lost from memory, the relearn procedure is very complicated. :) Drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals. That will meet the conditions for the computer to know your foot is off the gas pedal. It will memorize the voltage reading from the throttle position sensor. From then on, whenever it sees the same voltage, it will know it must be in control of idle speed. Until then, the engine will typically stall at stop signs due to idling to slowly. The problem can be overcome by jsut holding the gas pedal down 1/4".
caradiodoc
Jun 18, 2010 at 10:32 PM
