1996 Dodge Intrepid Leaking
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
THESANTICK
Hi, the rear left tyre in my car is leaking breaking fluid.
it leaves a bid puddle of liquid everytime i fill it in.
can you help me?
can i repair it myself?
thanks
Jun 26, 2009 at 10:26 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Can you see where it comes from? Is it leaking from a line? I would suspect a faulty wheel cylinder.
Jun 26, 2009 at 11:21 AM
THESANTICK
[quote:ad6a4ab467="bluelightnin6"]Can you see where it comes from? Is it leaking from a line? I would suspect a faulty wheel cylinder.[/quote:ad6a4ab467]
I am not sure where it comes from. I took the tyre out and the inside was all wet. I dont think comes from a line.
Can I drive it to the nearest mechanic? or I wont b able to break at all
Jun 26, 2009 at 11:28 AM
BLUELIGHTNIN6
  • 16,542 POSTS
The brakes will most likely lock up due to the fluid being on the rear brakes. You can drive extremely carefully and slowly , have someone follow you to the mechanic. Make sure you have plenty of brake fluid in the master cylinder first though
Jun 26, 2009 at 11:33 AM
THESANTICK
[quote:f4ef45b84b="bluelightnin6"]The brakes will most likely lock up due to the fluid being on the rear brakes. You can drive extremely carefully and slowly , have someone follow you to the mechanic. Make sure you have plenty of brake fluid in the master cylinder first though[/quote:f4ef45b84b]
thank you.
Jun 26, 2009 at 11:35 AM
