1996 Dodge Intrepid Hello, I have a 96 Intrepid that I can'
94,000 MILES • 6 CYL • FWD • AUTOMATIC
SIWYTOM1957
  • 7 POSTS
Hello, I have a 96 Intrepid that I can't get to start.
Jul 11, 2010 at 8:15 AM
  • 75,988 POSTS
Hi siwytom1957, Welcome to 2carpros and TY for the donation
If its cranking over and will not start do below and get back with some testing results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 11, 2010 at 8:27 AM
SIWYTOM1957
  • 7 POSTS
new cam /crank sensors +coil no start no blu spark
Jul 11, 2010 at 11:54 AM
SIWYTOM1957
  • 7 POSTS
new cam /crank sensors +coil no start no blue spark
Jul 11, 2010 at 12:05 PM
  • 75,988 POSTS
Check fuse B 20amp.Turn key to run and check for power on the dark green and orange wire to the coil if no power here test the ASD relay if okay -your problem is coming from the computer
Jul 11, 2010 at 12:38 PM
