1996 Dodge Intrepid cranks wont start have changed
18,000 MILES • 6 CYL • FWD • AUTOMATIC
SCHWINN09
have changed ign switch cam & crank sensor
no fire no fuel pump no check engin light
is it time to try a computer?
ecm pcm ecu?? need some help please have to get the kids car out of my drive thanks Ed
Feb 8, 2010 at 3:42 PM
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer.
Feb 8, 2010 at 4:24 PM
