1996 Dodge Intrepid cranks wont start have changed
SCHWINN09
  • 1996 DODGE INTREPID
  • 6 CYL
  • FWD
  • 18,000 MILES
Have changed ign switch cam & crank sensor
no fire no fuel pump no check engin light
is it time to try a computer?
ecm pcm ecu? Need some help please have to get the kids car out of my drive thanks Ed
Monday, February 8th, 2010 AT 11:42 PM
Check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer.
Tuesday, February 9th, 2010 AT 12:24 AM
