1996 Dodge Intrepid Compresser clutch
1996 DODGE INTREPID
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
MOXETTE
The car's pulley begins to wobble when the defroster or a/c is engaged. Before I take it to have it worked on I need to know if it is the whole compressor or the clutch.
Feb 4, 2009 at 11:54 AM
2CARPRO JACK
  • 11,533 POSTS
May just be the hub assembly on the front of the compressor. Usually if it is a bearing problem, but the a/c still works good, you can just replace the clutch/hub assembly and it is ok
Feb 4, 2009 at 1:04 PM
