1996 Dodge Intrepid check enging light
110,000 MILES • 6 CYL • AWD • AUTOMATIC
INSANENITALIAN
should the check engine light flash then go off when you start up the car - 1996 dodge intrepid
Mar 25, 2009 at 3:10 PM
  • 75,988 POSTS
You need to scan the computer for OBD2 code/s there's a problem within the engine management system this is your starting point to find out what's causing the CEL to lit.
Mar 25, 2009 at 4:44 PM
INSANENITALIAN
thankz for your reply...im asking because im looking to buy a used intrepid and i want to know if it does flash when started up...jus to see if the seller pulled the bulb for the check engine light and is trying to get over on me...i tried looking for the owners manual online but no luck and i came across this siiite looking for help
Mar 25, 2009 at 5:51 PM
  • 75,988 POSTS
The CEL should come on when your turn key to run position and then goes off when the engine starts. And should not come back when engine is running
Mar 25, 2009 at 7:11 PM
INSANENITALIAN
dude thankz alot i appreciate your help
Mar 25, 2009 at 7:15 PM
