1996 Dodge Intrepid car quits
HILLBILLY38
  • 1996 DODGE INTREPID
  • 6 CYL
  • FWD
  • 260,000 MILES
Why does my 1996 dodge intrepid quit then if it sits for a while it will restart
Monday, January 5th, 2009 AT 7:59 AM
JDL
  • 16,098 POSTS
Did you check for codes? You can check for some codes by cycling the ignition switch, on--off, on--off, on. You don't crank it, just turn the key till dash lites come on. Watch the MIL, count flashes to get the codes.
Can you do some of the basic tests? When the problem occurs, have a helper crank it, while you check for spark at the plugs and injector pulse.
Can you check fuel pressure? You need a gage for that.
Monday, January 5th, 2009 AT 12:58 PM
