my car jolts in overdrive ..could that be a .. transmission model or a control model.. or a ground wire????
Jul 23, 2010 at 5:06 PM
✓Experienced Mechanic
Any of the above. Has the check engine light come on? Does it feel like it could be an engine miss under a load?
Jul 23, 2010 at 5:16 PM
DOMINICK32310
MEMBER
the check engine light is on
Jul 24, 2010 at 4:14 AM
If the check engine light is on, you need to have the computer scanned to identify where the problem is coming from. What I recommend is this. Take it to a nationally recognized parts store and have them scan it. Most will do it for free. Once you do that, let me know what you find.
Jul 24, 2010 at 4:30 PM
DOMINICK32310
MEMBER
ok ill do that sunday well today and let u know what codes come up
Jul 24, 2010 at 5:09 PM
Honestly, like you I can't believe the time either. Let me know how things work out for you.
Jul 24, 2010 at 5:27 PM
DOMINICK32310
MEMBER
i went got it looked at.... it came up.. number 1 cylinder head misfier and a p701/7 code saying engine lean i ( bank)... what can i do to fix that problem and what does it mean ???
Jul 25, 2010 at 11:33 AM
Basically, it is telling you that the #1 cylender has a mis. It could be caused if a tune up hasn't been done for a long time, an ignition wire that is arcing... My concern is the lean mixture. Have you checked for vacuum leaks to the engine? If too much air is getting into the engine, then a lean mixture will occurr. Also, let me know when the last tune up was done.
Jul 25, 2010 at 6:24 PM
DOMINICK32310
MEMBER
i just did a tune up today, oil change oil filter , spark plungs and wires air filter i replaces 3 vaccum hoses that were bad.. i got it scan agin it took the misfire problem away.. but the engine lean is still there??? could it be an oxygen sensor???
Jul 26, 2010 at 1:04 PM
It could be an O2 sensor, temp sensor, or a vacuum leak that was missed. I will add that a bad O2 sensor usually shows up on the scan.
