1996 Dodge Intrepid
165 MILES • 4 CYL • FWD • AUTOMATIC
CANA
About two weeks ago my vechilebegan running at a high idle. The MPH needle would read between one and two, the vechile only runs at a high idle while in park reverse and neutral. When in drive the shifts back to low (makes a lower sounding idle). I am wondering if you could give some suggestions to why this may be happening or know the cause.
Thanks
Cana
Jul 27, 2010 at 4:06 AM
  • 110,251 POSTS
Hi:
Has the check engine light come on? It sounds like either the idle air control valve or throttle position sensor is the problem, but I can't be sure without a code.
Jul 27, 2010 at 5:46 PM
