1996 Dodge Intrepid
BLARMILO
1996 Dodge Intrepid 170000 miles
My ac power windows and locks all won't work also the blinkers and radio will not work unless you jiggle the ignition what do I need to check to get the ac and power windows to work again everything was fine two days ago then suddenly it all stopped all fuses are good and can't find a short it has me baffled
Apr 13, 2010 at 8:49 AM
CH112063
  • 1,320 POSTS
If jiggling the key helps replace the ignition switch. It's not too bad of a job. You'll need special torx drivers.
Apr 13, 2010 at 1:17 PM
