1996 Dodge Intrepid
AMERICAUNITE
1996 Dodge Intrepid
so the car was turrning over but not starting. Had narrowed it down to fuel filter,by the help of your site. :) Today went to try it before going to by fuel filter and it started runs smooth no warning lights turned on dash. Now the heater and windows will not work. This happend about 4 months ago and once again to your site I was told ignition switch. And that fixed the problem. :) Why would this be happening again already? Could it be a short or fuze or should I replace the switch again? Help please!
Nov 28, 2009 at 6:44 AM
MERLIN2021
  • 17,250 POSTS
I sent a PDF to your email, test switch continuity, also if it tests OK check wires, two charts are in the file, one is continuity, other is wire colors and what they are, test battery feeds and ground...
Nov 29, 2009 at 1:55 AM
MYDRAGONS_ANGEL
Any chance I could get a copy of that wiring diagram? I never figured something like this would be so hard to find.
[quote:46abdf87e6="americaunite"]1996 Dodge Intrepid
so the car was turrning over but not starting. Had narrowed it down to fuel filter,by the help of your site. :) Today went to try it before going to by fuel filter and it started runs smooth no warning lights turned on dash. Now the heater and windows will not work. This happend about 4 months ago and once again to your site I was told ignition switch. And that fixed the problem. :) Why would this be happening again already? Could it be a short or fuze or should I replace the switch again? Help please![/quote:46abdf87e6]
Nov 30, 2009 at 10:41 AM
MERLIN2021
  • 17,250 POSTS
Check yoyr email.
Dec 3, 2009 at 7:38 AM
