1996 Dodge Intrepid
AMERICAUNITE
1996 Dodge Intrepid
Just all of a sudden the power windows, ac and heating works only sometime. If one does not work either does the other. If i restart the car it usually will kick on sooner or later. The last couple of days it will not work at all. I was thinking a fuzable link but I cant find a wireing diagram. Thank you for your time
Aug 9, 2009 at 2:24 PM
BMRFIXIT
  • 19,053 POSTS
Fuse or fusible link once off always off
I would suspect bad ignition switch
next time it happens wiggle ignition key in place if all worked again its for sure bad switch
Aug 10, 2009 at 10:43 PM
