1996 Dodge Intrepid
191,150 MILES • 6 CYL • FWD • AUTOMATIC
EDDIESIFUENTES
My temp gauge does not work,also noticed cooling fans not coming on.Replaced coolant sensor still gauge inop.when ac is on fans work.what should i do next?
Nov 6, 2008 at 4:18 AM
  • 110,248 POSTS
Hi:
Have you replaced the temperature sending unit? If not, try that. If you have replaced it, you will need to check for a broken wire.
Nov 8, 2008 at 8:24 AM
