1995 Dodge Intrepid stalls out when it comes to a stop
120,000 MILES • 6 CYL • FWD • AUTOMATIC
NELLYCHAMPAGNE07
how do i repair this problem. my car stalls out when i come to a stop?
Jan 9, 2010 at 12:35 PM
CH112063
  • 1,320 POSTS
Idle speeds are all controlled by the throttle blade position and a small motor called an IAC motor, it may need to be cleaned, you can test the system for fault codes when the throttle body is serviced. I hope that cleaning up the throttle body may be all it needs, has it been tuned up lately? The air filter being clogged can do this. ok
Jan 9, 2010 at 12:47 PM
