1995 Dodge Intrepid Over Heating
98,250 MILES • 6 CYL • 2WD • MANUAL
DJUDY
The engine over heats. Fans come on after several minutes during warm up. I have been told that it maybe a head gasket issue. If that is true would I not have oil in the water or water in the oil? I do not have either. Any suggestions
May 17, 2009 at 2:01 AM
CRUISE816
  • 7 POSTS
it depends. i had the same problem with my 94. the problem with mine was the gasket between the inner and outter intake manifolds was leaking. i know it sound dumb but there is coolant running between thats where the thermostat is located. i have the 3.5 if you have the same motor i would start with the therm and then check the intake gasket. let me know what you find out
Jun 1, 2009 at 3:05 PM
