HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Intrepid
Ignition
No Spark
SPONSORED LINKS
1995 Dodge Intrepid no fire to the coil
FOGUIE MCKINNIE
MEMBER
1995 DODGE INTREPID
Electrical problem
1995 Dodge Intrepid 6 cyl Two Wheel Drive Automatic
should there be frie at the coil all the time if yes what could be worng if I don t
Thursday, September 9th, 2010 AT 4:59 PM
ERNEST CLARK
MECHANIC
The computer first needs to see a signal from the crank and cam sensors before it'll send a signal for the coils to fire.
Also, the ignition switch and the connectors/wires could be bad (don't forget the fuse)
SPONSORED LINKS
Friday, September 10th, 2010 AT 6:46 AM
Please
login
or
register
to post a reply.
Related No Spark Content
1997 Dodge Intrepid No Spark No Fuel
Computer Problem 1997 Dodge Intrepid 6 Cyl 1997 3.3 Engine. Gets No Spark And No Fuel. Have Replaced Iac Sensor. Blowes Fuses When...
Asked by
smm1225
1 ANSWER
1997
DODGE INTREPID
GUIDE
Ignition Spark Check
An engine's ignition system is responsible for igniting the fuel-air mixture inside the combustion chamber and when the ignition process stops the engine will not run....
2002 Dodge Intrepid No Spark
Electrical Problem 2002 Dodge Intrepid 6 Cyl Front Wheel Drive Automatic 2002 Intrepid 2.7 V6 Motor. No Spark On 2 Cylinders. Can...
Asked by
Auto Alan
1 ANSWER
2002
DODGE INTREPID
2000 Dodge Intrepid No Spark...
Electrical Problem 2000 Dodge Intrepid 6 Cyl Front Wheel Drive Automatic 85.000 Miles My 2000 Dodge Intrepid Was Running And One Day It...
Asked by
Hrose09
2000
DODGE INTREPID
No Spark In 2,3,5,6
I Have A 99 Dodge Intrepid 140k Miles On Car 0 Miles On Motor.I Just Installed A 2002 Rebuilt 2.7l Engine. I Cant Seem To Get Spark I Am...
Asked by
dannybeuck
DODGE INTREPID
I Recently Replaced The Timing Chain Tensioner And After Putting It All Back Together The Car Would'nt Start. I've Done Some Testing And...
Asked by
cknutson4
2000
DODGE INTREPID
VIEW MORE
SPONSORED LINKS
Ignition System Testing
Ignition Coil System Test Repair - All Cars
Crankshaft Sensor Symptoms
Online car repair manuals
