1995 Dodge Intrepid need help
160,000 MILES • 6 CYL • FWD • AUTOMATIC
NRATACZAK
the gauges in my car stopped working (speedometer,fuel, and tempature) all do not work. I checked all fuses but seing that they are not digital I realize that was probably a waste of time. do you please have any suggestions.
Apr 17, 2010 at 7:48 AM
CH112063
  • 1,320 POSTS
If the 2 5 amp fuses light a test light on both sides of each fuse, first check all the power cemter fuses near the battery. The cluster gauges power is a red/wht wire, remove and check it. Then you'll need a scanner before replacing the cluster. ok
Apr 18, 2010 at 1:43 PM
