1995 Dodge Intrepid loosing brake pressure
BLKKNIGHT
  • 9 POSTS
Brakes problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 85.000 miles
i have a 95 intrepid which looses brake pressure. and first i found out that the brake line at the distribution block was loose along with the fact the rear brake were not connected at all, someone ran a loop from one rear line outlet to the other. but i bleed the front brakes and i still am loosing pressure, but i get it back after a few secs. don't know if i need a new master cyl. or brake booster or what. any ideas?
Sep 23, 2009 at 7:56 AM
  • 75,988 POSTS
If you're not leaking anywhere I'll will start with the master cylinder could have an internal leak or its not bleed properly.
Sep 23, 2009 at 8:23 AM
