1995 Dodge Intrepid Ignition problems
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBGRATHWOL
My Intrepid has an intermittent problem with the ignition. When the problem presents, the car will turn the starter, but not start. The dash lights seem to work, but the gas gauge does not show any gas and there is no sound of the fuel pump priming. You can turn the key for a couple of times and it does this, then the next time, everything works normally. The gas guage shows the proper reading, the fuel pump hums and the car will start after a normal turning of the starter moter. The shop can't make it do this, so they can't find the problem. What should I look for? How can I test for this?
Feb 10, 2008 at 8:32 AM
BMRFIXIT
  • 19,053 POSTS
[quote:6f10d9d39b="bobgrathwol"]Electrical problem
1995 Dodge Intrepid 6 cyl Two Wheel Drive Automatic 110000 miles
My Intrepid has an intermittent problem with the ignition. When the problem presents, the car will turn the starter, but not start. The dash lights seem to work, but the gas gauge does not show any gas and there is no sound of the fuel pump priming. You can turn the key for a couple of times and it does this, then the next time, everything works normally. The gas guage shows the proper reading, the fuel pump hums and the car will start after a normal turning of the starter moter. The shop can't make it do this, so they can't find the problem. What should I look for? How can I test for this?[/quote:6f10d9d39b]
check /replace ASD relay
Feb 12, 2008 at 10:27 AM
BMRFIXIT
  • 19,053 POSTS
Thank you for your kind words (in u r PM)
its my pleasure to help
all I would add after reading your PM
is I think if ASD ok then the crank sensor bad
be prepared for it
Feb 12, 2008 at 11:28 AM
