1995 Dodge Intrepid Help
IGNATS12
  • 1995 DODGE INTREPID
  • 6 CYL
  • FWD
  • 196,000 MILES
I havelost all insturmation, RPM, Speedometer, Gas, etc. Plus the wind shield wipers do not work. I have checked the fuses in the engine compartment and at the side of the interior. Ineed to go to a junk yard to find a replacement. What do I asked for?
Thursday, June 3rd, 2010 AT 8:32 AM
2CARPRO JACK
  • 11,533 POSTS
The body control module is behind the right kick panel, this may be the problem. Remove the controller to access the wiring (while plugged in) use a test light to verify ignition power (key on) at the 2 Dark Blue/White wires. If it has power, the controller may be bad
Thursday, June 3rd, 2010 AT 3:54 PM
