1995 Dodge Intrepid Heater blows luke warm.
VIKEZFAN
  • 20 POSTS
Heater problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
I am working on a '95 intrepid that only blows luke warm air when heat is on. Flushed heater core both forward and backwards 4 times. Both hoses going through the firewall to the heater core get hot now (they weren't before). Still only blows luke warm. Has manual heater controls. Went through diagnostic mode and everything checks out. Checked that blend door actuator was moving. Removed proper fuses to 'calibrate' blend doors and let sit for 10 mins. Reinstalled fuses and listened while turning the temperature control listening to the blend door move and the air flow change throughout the entire range. So, as I see it, I have eliminated the heater core, control, and blend door. What am I missing? It still blows luke warm air.
Nov 3, 2008 at 6:26 AM
  • 110,244 POSTS
Hi:
When the car is hot and the heater is on, do both heater core hoses get hot (Inlet and Outlet)? If not, the coolant isn't getting throught the core. It could be switch or air lock. With the car off, remove the outlet hose at the motor and make sure the coolant has made it through the system.
Nov 4, 2008 at 4:56 AM
VIKEZFAN
  • 20 POSTS
Yes, both heater hoses get hot.
Nov 4, 2008 at 5:59 AM
  • 110,244 POSTS
Hi Again:
If both are getting hot, then there has to be a vent door not opening. Are you able to get to the heater core? If so, check to see if the heater door is opening.
Nov 4, 2008 at 1:16 PM
VIKEZFAN
  • 20 POSTS
The blend door APPEARS to works properly. You can hear the airflow change throughout the movement of the temperature knob.
I don't know if this helps, but the heater will blow hot when first turned on for a few seconds then it fades to cool air. Does the blend door need calibrated? To double check what I think I know, what is the blend door calibration procedure where you pull a fuse for a 1995 Intrepid?
Dec 1, 2008 at 8:01 AM
  • 110,244 POSTS
Hi
If it blows warm then cools, are you sure the coolant system is full? Also, is the car running at a normal operating temp?
Dec 2, 2008 at 5:39 AM
VIKEZFAN
  • 20 POSTS
The coolant is full and I have bled the system 3 times. However, the engine appears to be running cooler than normal according to the temperature gauge.
Dec 2, 2008 at 6:00 AM
  • 110,244 POSTS
Hi:
It sounds like the thermostat needs replaced. Remember, when you turn the heater on, the core acts as a small radiator cooling the engine more. If the t-stat is sticking open, it may not allow the engine to get hot enough.
A t-stat is a cheap part. If you need help replacing it, let me know.
Dec 2, 2008 at 11:15 AM
WTPIV
If you have not found the answer, here you go...
I had the exact same issue with a 97 trep this week. I am a 30+ year mech and this one baffled me. I replaced a good thermostat. Flushed the core, the engine, and radiator(needed that anyways). I could bleed the cooling system and have 114f degree heat out of the vents but would demenish to 70f by about the 10 mile range. The coolant was full and the water line going into the core was 170f and 160f coming out. It made no sense at all! The blend door was functioning properly but still no heat!
I searched the internet from one end to the other about this problem without any luck and decided to go ahead and do the big nasty and remove the core. A full skill level 10 job and requires some special tools to get er done. But I found the problem. The oem heater core has a plastic top resivior which had a hair line crack. Seeing that the heater core is above the fill line of the coolant resivior, it all made sences at that point. The heat going in and out of the core was just steam and being above the fill line of the engine and coolant resivior, the car would not over heat or loose coolant.
Sorry to pass along the bad news, but it sound like the core is bad. I hope this helped. The car I am working on is for a friend from church so I wont charge them too much. But I wont ever touch another one for under $1000! The dealership is around $1200.
Good Luck and have a Merry Christmas:)
Dec 13, 2008 at 9:51 AM
