Heater problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
I am working on a '95 intrepid that only blows luke warm air when heat is on. Flushed heater core both forward and backwards 4 times. Both hoses going through the firewall to the heater core get hot now (they weren't before). Still only blows luke warm. Has manual heater controls. Went through diagnostic mode and everything checks out. Checked that blend door actuator was moving. Removed proper fuses to 'calibrate' blend doors and let sit for 10 mins. Reinstalled fuses and listened while turning the temperature control listening to the blend door move and the air flow change throughout the entire range. So, as I see it, I have eliminated the heater core, control, and blend door. What am I missing? It still blows luke warm air.
Nov 3, 2008 at 6:26 AM
