1995 Dodge Intrepid fuel pump
147,000 MILES • 6 CYL • FWD • AUTOMATIC
BRYNSTAC
here's the problem...while driving,my car just died..got it to my father-in-laws roofing company shop and pulled the lines off the fuel pump to see if it was pumping fuel..it wasnt...thought fuel pump went..installed a new one..still no fuel..tested wires at fuel pump..no power to it..checked fuse..it was good..tested relay..it was good...tested fuse box where fuse goes for fuel pump..no power to the fuse box for the fuel pump fuse..is it a computer problem or a wiring problem?..oh yeah..we also took a wire and ran it straight from the battery to the fuse itself in the fuse box and the car started....ok...went and worked on it figured it out..tested asd relay..it was good...was double checking fuse and noticed when i turned on the key nothing on my dash was working either...turned out to be the ignition switch...replaced it..car fired right up....if anyone else has this problem with the fuel pump..check your dash panels..would have saved me alot more time ..thanks for the help tho
Jun 28, 2008 at 6:41 AM
  • 75,988 POSTS
Inspect and test the ASD relay-
Jun 28, 2008 at 8:23 AM
