1995 Dodge Intrepid engine shuts down error codes found doi
OZRIC
Engine Performance problem
1995 Dodge Intrepid 6 cyl Front Wheel Drive 80000 miles
what do error codes 12 42 33 and 55 mean. I already replaced the ignition coil. I think I should replace the PCM, but not sure?
Jan 16, 2010 at 3:10 AM
CH112063
  • 1,320 POSTS
12, is for a battery disconnect, 33 is for the a/c clutch relay, and 42 is the auto shut down relay.
55 means you've ended diagnostics, and the shutdown and a/c relays are both fused, maybe a fuse is out, they are located in the power center, the PCM grounds them, I would go to this box first and test the fuses using a 12volt test light, its the best way to check if power is getting to the fuse and coming through it. You can purchase a good test light at the store and read the sections about testing the fuses. I don't know if the relays are bad but I think its best to test the power center fuses first. The black lid has each fuse and relay identifications.
Jan 19, 2010 at 2:24 PM
